It must be clipped on some how
SOURCE: Eureka the boss vacuum cleaner brush won't turn
Take the top cover off, remove the torx screws on each side of the motor housing, remove the screw on the back holding the hose, then you just have to compare the 2 before putting on the new one. Can't tell for sure without a model number to get you a picture. What isn't on the new base, take off the old base and put it on the new one.
SOURCE: vacuum cleaner by bosch
Visit www.stevessewandvac.com for bags if you don't see them up on the site contact us. On the average you should change your bag once a month regardless of how full this will keep your vacuum from taking on odors of pets or whatever it is you may have sucked up. Also if you happened to have sucked up any food products they tend to start to grow things.
SOURCE: Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
SOURCE: How do I remove the air filter on a 1996 Chrysler
there should be a box at the other end of the intake hose with two clamps on it after unclamping it pull the top away from the box then pull up
SOURCE: grill removal
the lower clips are pushed down with a long screw driver from the front , when the grill is removed the clips need to be removed from the vehicle and put in the grill then push the grill in
