Sir/mam
Power off the machine power on with the 2 and 5 depressed. Then go to soft switch set 3-1-1 if the code comes back its the fuser have a tech look at as it can start a fire ruining a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: help
your heat lamp is not turning on, did you change it? generelly some copiers that old may have to disapate charge in the electronics after being worked on. if the copier did not initiate after rebuilding or doing work on the fuser, you may need to actually unplug it from the wall, like a reboot. the electronics are dated 8 to 10 years old. make sure, if it has a power relay or fuse, because of its age , they are good. generally older units will fire back up at off and on. if nothing works, let us kow.
SOURCE: service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
SOURCE: my konica minolta copier says call sevice code
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "2" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
