This simply means the printer has a problem. Just make sure that nothing is jammed in it and restart. If this does not work then this is the next step. The printer either is not turning due to something stuck in it or it is not able to sense rotation. If you are not familiar with electro mechanics, take it to a dealer to have the printer tested. Otherwise, check all sensors and motor windings, connections to printer etc. Hope this helps!
SOURCE: Royal Cash Register 120 CX
we'll find that for you..in meantime, try not to run any transaction, eh?
SOURCE: Eror code E01 in sanyo ecr 140 cash register
Hi.
Sanyo information is very scarce as they are a very small player in the register market now, so I have no details on the 140. However, the standard error E01 usually refers to lack of clerk. This means you must sign a clerk onto the machine. See if you have a clerk or cashier button. Press 1 then clerk.
SOURCE: how do i resolve an E-32 error code on my sharp cash register
Press the cash# button then press 1 then press cash# again (cash# is next to the clear button)
SOURCE: Cash Register Casio 240cr displaying error code E94
Your printer is jammed, mistimed, or broken
SOURCE: CASIO TE2200 CASH REGISTER ERROR INIT/FC
This machine has lost everything. It has either had a flat battery (internal rechargeable) from sitting for more than 2 months or it has not been set up from new with the dealer settings.-------------------------------------------------------------------------------------------------For those of you that have asked for a Casio TE-2200 manual, here it is: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
