20 Most Recent VeriFone VX510 Questions & Answers
verefone the terminal has a problem in the display shows bad rtc chip, as I can compose for it functioning properly again?
VeriFone VX510 | Answered on Sep 14, 2018
what you need to do is call your service provider ( bank ) and have them download the program in to the unit what the unit is telling you is the there is no files in the memory
VeriFone VX510 | Answered on Aug 03, 2018
primero dime si eres tecnico
VeriFone VX510 | Answered on Jun 23, 2018
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
VeriFone VX510 | Answered on Jun 22, 2018
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Select CLOCK [F3].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time. Key in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.when finish Select Restart [F4].
VeriFone VX510 | Answered on Jun 02, 2018
PDF]Verifone VX510 User Guide - Moneris Solutions
www.monerisusa.com/support/~/media/Files/.../Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
[PDF]Vx 520 - User Guide - Verifone Support Portal
VeriFone VX510 | Answered on Feb 05, 2018
if you have a tamper you may need to get it replaced, try this press enter key and if it takes you to a menu press set up, enter password, do you have the password? 1 alhpa alpha 66831 ( the alpha key is above the 2) then press more until you see date and time, change date and time see if this fixes tamper or press red x until you get antoher screen or press f2/f4 same time enter password and then clock change time if this does not work you need a new terminal
VeriFone VX510 | Answered on Oct 04, 2017
To Reboot the Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
VeriFone VX510 | Answered on Dec 12, 2016
if you still seeing the backlight of the display, your lcd maybe bad in shape. the display assembly needs to be replaced. or maybe some other problem causing it too. if you still needs help on your verifone8020, call (775)358-2922 look for randy and maybe we can help you. thanks
VeriFone VX510 | Answered on Feb 01, 2016
Simply unplug the line Cabletrace it to the other end and disconnect it
VeriFone VX510 | Answered on Jan 23, 2016
Probably the best way to correct this problem is to clear the RAM and download your app. again. In other words start over with a clean slate. After doing this you still have the same problem, you may need to open the machine and disengage the battery. This would clear the RAM, but you would then need to clear the tamper error message. Call Frank @ 775-338-6634
VeriFone VX510 | Answered on Aug 01, 2015
VeriFone VX510 Logo
317 questions posted
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Marvin
Marvin
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
View Most Popular
  • VeriFone Retail Supplies
Most Popular Question
verifone vx520 tamper please enter
  • Retail Supplies
