SOURCE: Connections on back of TV
You can download the manual from the link below: http://www.emersonaudiovideo.com/pdf/om/EWL3706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: connecting Gateway HDMI TV to Playstaion 3
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
SOURCE: Connecting Wii to Emerson 37 in LCD tv
Finally found the correct point of entry to tv and correct channel on my own.
SOURCE: Connection cord problem from VR375 to TV set?
Page 18 of the user manual for your device shows that there are normal video (yellow) and audio (red/white) connectors underneath the A/V out column of connectors - Since your son's TV does not have an HDMI cable (all you would need if that were the case) make sure you connect the A/V out column to the RCA type inputs of your son's TV.
The manual can be found here:
http://downloadcenter.samsung.com/content/UM/200802/20080229102004125_01613A-01-VR375-XAA-ENG-BM-0228.pdf
