This is not an Ink printer, it's probably a thermal stylus which is very delicate and breaks easily. You must also be using the correct paper as not "any" paper will due. Do NOT touch this printer as it gets very hot and like I said is very delicate. May also want to check the battery although I doubt it's a battery issue.
SOURCE: Paper starts then stops before printing results
most likely wrong paper or a bad optical sensor. There are actually 2 or 3 different versions of the mac 1200 all of which might need different paper. if you tell me the serial umber of your unit and the part number for the paper you are using I can tell you what is the correct paper.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
SOURCE: When try to record ekg tracing on my MAC 15 EKG
Hello n_baluyut, visually check the RS232 plug pins, both male
SOURCE: I think that the ink on my GE Mac 1200 EKG has run
hi,
it doesn't uses any ink. printout is given by a thermal printer on wax or chemical paper. if print out is not coming ,then there may be possibility of the thermal printer head become damaged.
also check the battery .
ok
SOURCE: Our MAC 1200 ekg machine
hi,
1.Press the setup Button
2.Select operating mode and press enter.
3. Repatedly perss the down arrow until it reaches to the "START AT QUEUE MARK" and perss enter. Then select NO and press enter ( if it is selected Yes then before each recording the recorder advance the paper to the beginning of the next page)
4. Press the Start button to exit the setup.
From the next EKG it will print from the first page.
ok
