Garden Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pressure washer has no pressure - Coleman Garden
Anonymous
Level 2:
Sergeant:
  • Expert 384 Answers
  • Posted on Jul 30, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
384
Questions
0
Helped
222358
Points
916
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Where do i get a 2200 psi pump?
It depends on what you want the pump for, but at 2200 psi, I presume you are looking for something like a pressure washer pump.
Harbor Freight sells a 1600 or 2500 psi pressure washer
http://www.harborfreight.com/2500-psi-3-gpm-65-hp-212cc-pressure-washer-69734.html
If you need just the pump, here are a couple of websites to check out:
Pressure Washer Direct
http://www.pressurewashersdirect.com/power/pressure-washer-pumps.html
Northern Tool
http://www.northerntool.com/shop/tools/category_pressure-washer-accessories+pressure-washer-pumps?utm_source=Natural&utm_medium=Covario&utm_campaign=Pressure
And you can check on Amazon or eBay and see if someone is selling one there.
Sep 04, 2014 • Garden
4helpful
3answers
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 • Garden
5helpful
4answers
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
1helpful
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
2answers
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
Northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
4helpful
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
5helpful
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 05, 2009 • Garden
Top Coleman Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Garden Expert? Answer questions, earn points and help others
