Garden Logo
Wayne O'Neal Posted on Nov 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant pull the starter cord on mt coleman ct200u
Clive
Level 3:
  • Master 882 Answers
  • Posted on Nov 22, 2017
Clive
Master
Level 3:
Answers
882
Questions
30
Helped
212854
Points
3292
Remove cover over starter pulley.
Cord wraps around this.
When cord is pulled, centrifugal force swings spring-loaded weights out, to engage the starter gear.
Check that weights are releasing when not pulled.
And that cord is still on pulley.
May have wound off the side.
1 Related Answer
Anonymous
  • 6468 Answers
  • Posted on Apr 02, 2012
SOURCE: Lawnmower hit a stump and now can't pull starter cord
you may have bent the crank shaft if it pulls hard and pulls back then remove the flywheel and check the key
2answers
I can’t pull the starter cord on my colmen CT200U-EX
check U tube Videos, especially the first one that lasts several minutes and goes over many facets of the machine.
Apr 02, 2020 • Garden
How do I replace the pull cord on my maxa 3000 Coleman generator?
Pull cord repair is pretty generic. There are lots of videos on YouTube if this one doesn't help.
HOW TO Generator Pull Cord Repair
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Starter rope is locked. Cannot turn by pulling cord
Hi Bob:
Sounds like the engine is seized.
Try removing enough bits so you can access the flywheel and see if you can turn it. Make sure ignition is OFF.
If the flywheel does not turn it will be time for a learning experience, a trip to the maintenance shop, or a replacement.
2answers
Why cant I pull the starter cord
If its on the compression stroke when you are pulling it will be hard to pull it, because you're fighting against the compression of the engine, make sure the valves are at the correct position and not fully closed when you are pulling.
1helpful
Apr 01, 2012 • Garden
Top Coleman Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Garden Expert? Answer questions, earn points and help others
