I was told this was a problem with the heating element, but the dryer is still getting hot. It will run for a few mins then the code will pop up. If you resume the cycle, it will continue to run for several mins then stop. Since there is heat, could there be another problem?
That has three sets of coils in it,one of them is bad this is most likely why you still have heat,i've seen it a few times,change out the heater box,go here and look at the last picture,you'll see the three sets of coils one of them is broken,just order your heater box for your model number off of your dryer.change out the heater box
https://www.appliancezone.net/134792700-frigidaire-dryer-heating-element-replacement/?gclid=Cj0KCQiAvrfSBRC2ARIsAFumcm_UzfGwntvtSVc9IDruzrS145S-0pcaF2W7iBwEOgT2y1r4boAgEPAaAoi4EALw_wcB
get in there with a meter and read out each coil on the heater to make sure this is your problem,like i said i've found when there is still heat it was one of the coils on the element was broken the other two coils would heat but your not getting full heat
https://www.youtube.com/watch?v=ktpNz3xV...https://www.youtube.com/watch?v=JwMyoSa9...
here's 2 ways to get into your dryer don't know what model you have you didn't send it but this should cover you,also like i said open the door to your dryer,look around the opening to see the tag with the model number on it,you need the number so you can order the correct parts for your dryer,usually an element has 2 connectors power comes in and out the other wire so if the element breaks you wouldn't have heat,your heater has 3 connectors so if one breaks you'll still have heat but the dryer isn't running hot enough so it will give you the error.if it was a t-stat you wouldn't have any heat,once they fail they won't work again.hope this helps you out and good luck
SOURCE: Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
SOURCE: Frigidaire electric dryer model # LEQ2152ESO runs
probably a loose connection on the speed control board
