Question about Frigidaire Dryers
Frigidaire Affinity dryer error code?
Hi, I just bought a Frigidaire Affinity dryer (the 6000 series), and heard an odd sound. I went to check, and rather than the minutes showing on the screen, it looked like "A0" or "AD"? The bin was still spinning. Any ideas? The error code on my Affinity dryer is E5b, and it won't heat what is wrong?
Posted by upstatecat on
Sal De
  • Frigidaire Master
  • 2,699 Answers
You have a problem with the heat you can't just say it's the element or thermistor you have to unplug it,take it apart and get in there with a meter and check all the t-stats,element thermistor,if they check good you could have a bad computer board but hopefully it will be the element but if you just bought it the dryer is still under warranty for the first year so either call whoever you bought it from or the 800 number off of the machine
Posted on Jan 02, 2018
5 Related Answers
dragonsthatk
albert getty
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
Anonymous
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Posted on Sep 26, 2009
franktalk
  • 193 Answers
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
Posted on Nov 10, 2009
viento86
  • 25 Answers
SOURCE: I have a frigidaire affinity dryer that won't heat
CHECK THE THERMAL FUSE, OR THE COILS LOCATED OT TOP OF THE GAS VALVE CHANGE IT
Posted on Nov 11, 2010
Liza Timmers
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity Washer making clicking sounds after power outage.
Sounds like either the control board or the timer is faulty at this point. Contact a professional so they can diagnose the unit fully and repair where needed.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Jun 27, 2009 | Frigidaire Electric Dryer
HELLO,
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Open Questions:
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
Mar 18, 2019 | Frigidaire Dryers
Dryers Logo
365 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
