Made in June 1997 . And is a smart series
SOURCE: need instruction book
I was unable to locate your specific model using the information you provided however here is a link to the Philips website.
http://www.support.philips.com/support/html/index_us_en.html
They have a diagram to identify exactly which numbers they need to identify the appropriate manual. From there it should be a simple download to get the information you need.
I hope this helps, good luck!
Kym McC
SOURCE: i have a philips magnavox tv with the original
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
SOURCE: no remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
SOURCE: Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
