SOURCE: zd8000 keyboard is skipping letters and spaces
Hey I have an HP zd8000 also and I've experienced everything that you guys mentioned. What's a laptop without a battery if you can't take it anywhere? After two years, I got so frustrated. I researched HP's web site and came across a battery recall. I just got mines in the mail today (Dec. 1, 2008), and my notebook is portable again! :D They will ask for your battery serial number. While typing the serial number be sure not to mix up the letter 'B' with the number '8', or else it will show as invalid serial. This is the link for the HP Battery Replacement Program!
http://bpr.hpordercenter.com/sbpr/
I hope this solves your problem!
Patrick Rodrigues
[email protected]
SOURCE: Over sensitive touch pad, causes cursor to jump all over the LCD
Try control panel and double click the mouse icon then settings you can adjust sensitivity there
SOURCE: ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
SOURCE: The keyboard types more than one letter when
try going into the control panel. should see a mouse and key board setting try changing the sensitivity in there. I know you can do that with a mouse. some key boards are just sensitive just give it a light tap and it won't do that your holding it down to long.
SOURCE: While typing, the keyboard seems to randomly skip
reinstall your OS, everything will be fine
