SOURCE: ibm thinkpad keyboard. i type letters, numbers show up. fix?
find the "num lock" key and press it once. it is a tagger switch.
SOURCE: Gateway laptop keyboard typing incorrect letters
Windows has support for many input-languages, e.g., for keyboards made in France with accented characters,
and for the DVORAK keyboard layout (which is a complete
rearrangement of the letters on the keyboard for maximum
typing-speed).
Go into "Control Panel", and "Regional and Language" and click the "Language" tab, and switch to the "USA Keyboard".
SOURCE: laptop keyboard is typing numbers instead of letters
dude its so easy hehehe just press the function and insert key together and then its already ok!!!!!
a simple tnx is wat i need..:)
SOURCE: locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
A Text Services and Input Languages window opens.
Figure 3: Change Keyboard button
Figure 4: Add button
Figure 5: Add input language: US Dvorak keyboard selected.
The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
Figure 6: Keyboard tray icon
Figure 7: Move up button
SOURCE: can't type double letters can't backspace more
goto start---->control pannel-------->keyboard under speed tab set repeat delay short and repeat rate fast. check whether this works. else there would definitely be some problem in your keyboard
