My Brydge 12.9 keyboard has a key issue
For some reason, the "T" on my keyboard is either not adding he TT or doubling i as you see here
any way to fix this issue? it is a new keyboard
edit: key seems to be hyper sensitive to the touch.
  • Anonymous Jul 30, 2021
    what PC is this, ?
    the PC keyboard is bad if a PC. if one key fails that is a bad single key,
    replace it is what we do, always.
    Brydge 12.9 Pro+ Wireless Backlit Keyboard with Trackpad for iPad Pro 12.9" 3rd Gen <<<(THIS?)????
    did you read the manual first, and make sure all batteries are not bad or needs to be charged?
    what it does is:
    Transform your iPad Pro into a laptop with the space gray Brydge 12.9 Pro+ Wireless Backlit Keyboard with Trackpad for iPad Pro 12.9" 3rd Gen
    key word above is WIRELESS, and that means BATTERIES MUST BE GOOD wireless fails or drops bits.
    never have I seen any keyboard with a sensativty setting.
    yes on auto repeat feature for 40 year now to 1981 first PC,
    that is adjustable in many cases.
    but you said only T key, so its not the auto repeat.
    I call battery weak or bad or never charged per the book rules.
    this seen
    Charging is accomplished by way of the included USB Type-C cable.
    most things like this , all laptops and pads the manual say charge it for 12 hours, first.
    I have no apple anything and never will
    but in windows, we have control panel click in search box for keyboard and see 2 settings auto repeat delay and rate,
    and in BIOS too the same thing but just for it.
    I call weak battery in the board.
    when weak logic can fail. in all portable things on earth. (guessing lithium inside keyboard.
Don A
  • Computers & ... Master
  • 2,916 Answers
If unresolved, contact their customer service. https://www.brydge.com/pages/support
I would try the fix suggested for key lag on this troubleshooting page. https://brydge-keyboards.reamaze.com/kb/troubleshooting-ipad
Posted on Sep 18, 2021
I'm trying to turn pair my newest Brydge keyboard. Every time it says pairing took to long. What is the problem?
Hi. if you are pairing with your windowsPC, turnoff windows firewall and pair it. Also uncheck the option "hide from other devices" if it is there.
Brydge keyboard keys delete enter shift typing other characters?.....
Keyboard failing. Buy a new one thwy are cheap as chips
How to change from qwerty keyboard to 12 key phone pad on Huawei y200
Unless Huwaeii have added anyting to do with keyboards to language and keyboards in settings, you'll need to download one from the google play store.
My laptop is entering more than one character at a time when typing in my password for example its adding additional letters how can i turn this off
seems like something is ring with the keyboard, try an external keyboard, if the issue is still the same this will be a windows issue, once in windows tap on the shift key 5 times this will either deactivate sticky keys or ask you to activate sticky keys.
If it is not a sticky key setting issue then the problem most likely will be Hardware, did any liquid spill on your keyboard previously causing the key to malfunction causing the key to type extra characters?
If none then possible this is a faulty keyboard on the machine.
When I strike the apostrophe, quotation marks (or double appostrophe)appear. When I Shift + apostrophe, double quotations appear. Same thing happens with the tilde key. So far just these 2 keys...
Sounds like a defective keyboard. I seen issues when pressing a button it will trigger another key to be pushed or nothign displays at all. Try replacing keyboard since they are relatively cheap. othersie maybe a software issue
Computers & Internet Logo
Ekse
