SOURCE: my 60 inch tv is not turning on do i need it
Was this tv made between 1995 and 1997? The problem is in the large signal board. It has the flyback on it. You will need to find a servicer.
SOURCE: I have a 60 inch
Let me know model number of your 60 inch LG tv to find out possible cause of no remote operation.
I do not think that IR receiver is bad in your tv. Regarding dusty IR receiver lens, you can confirm it by sending remote signal by very close distance to tv.
There are few other possibilities of no remote operation problem instead of bad IR receiver.
SOURCE: i how a 60 inch tv that need screws for the base but don't know what size screws
CALL LG CUSTOMER SERVICE AND THEN GO TO HOME DEPOT ETC.
THEY ARE GOING TO BE STANDARD BOLTS.
SOURCE: I have a 60 inch LG plasma tv and it will not turn
If you are lucky one or more boards: power or main board are most likely---power board to some degree can be tested to see if voltages are present or not.....
Not knowing the model number all I would suggest is something arced in the set--try removing it from power and a box if used for a while and power back allowing units to reboot.
