Eiki model LC-NB2UW
SOURCE: Replaced XD300U projector lamp.
How to reset the operation time meter
Plug in the power cord, turn on the main power
switch, and reset lamp time by pressing the VIDEO
button and ENTER button for 3 seconds simultaneously.
• Make sure that the STATUS indicator flashed
twice and the operation time meter has been
reset.
Caution:
• Do not spill liquid on the lamp or place it near
flammable objects or where children can touch it.
Otherwise, it could cause injury or fire.
• Be sure that the projector guide is firmly inserted
between the right and left lamp guides.
Important:
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after
you replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
SOURCE: eiki lc4300 projector
check to make sure your lamp is completely in and connected properly, and the lamp door is closed completely, if still no light, pull the lamp out and make sure it is not broken from transporting it or handeling it.
Making sure you do not touch and glass portion of the lamp or surroundings. only touch plastic or "metal using clean dry paper towel for metal contact" as skin oil can destroy a lamp.
"If this dosen't help please reply for more help before marking a bad suggestion, thanks"
SOURCE: Display color problem, Eiki projector LC-NB2UW
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
SOURCE: sanyo plc xu 40 lcd projector problem
hi i have a infocus lp720 with new lamp but there red and green images all around the outside of things what is it and can this be fixed cheaply? thanks john
SOURCE: Shuts off after using it for a while....Eiki LC-NB2UW
I have the exact problem. I have been using a portable fan next to the projector to keep it cooler it allows me to use the projector for work. I know that this is not the "fix" but it helps. If someone has the solution, I would like to fix the projector.
