SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
SOURCE: Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
SOURCE: Janome Memory Craft 7000 Sewing
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
