SOURCE: Pride Lift Chair
Yes, jump, short, somehow bypass the switch and see if the chair moves. In 4 of 5 cases, I have had to replace the switch. Its the only part I carry with for "spares". Its an easy fix, and a lot cheaper than replacingt the whole hand control.
SOURCE: Switch Wireing Diagram
The motor operates on low voltage DC current Robert. You will have a negative and a positive, like a car. The center connector is a common, meaning that it will be connecting to the motor whenever you switch is activated to make it go, and the other two are positive and negative to control either up or down. These should be color coded red and black and will go to the outside connectors and the remaining wire will go to the center common connection. Hook it up and then test the chair lift button. If it doesn't lift, you need to reverse the two outside wires for correct polarity, or just use the switch controls opposite; up for down, down for up.
SOURCE: I NEED TO LOCATE MANUAL AND WIRING DIAGRAM FOR MY
You can view, download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
The wiring diagram is given on page 34 of this manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
