20 Most Recent Jet 3 Ultra Power Chair Questions & Answers
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Jet 3 Ultra... | Answered on Jul 11, 2018
The batteries will discharge below the reference voltage required for the charger to "see" the batteries if left uncharged for more than a month or more. You have to carefully bring the batteries back up to about 12 volts each for the charger to see them. The easiest way is take them to a qualified battery shop that has a step charger for sealed batteries. If you attempt to use a car charger on sealed batteries, you will ruin the batteries or even blow them up as the cases are sealed and the gas from charging has no way to escape. Some people have used a standard car battery charger on low only, applying a charge to one battery for about 15 minutes, then the other for 15, etc. until the batteries are back up to 12 volts, but again, using a car charger is dangerous and could cause the battery to explode.
Jet 3 Ultra... | Answered on May 23, 2018
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
Jet 3 Ultra... | Answered on Apr 23, 2018
Maybe charger took a surge and fried it
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jet 3 Ultra... | Answered on Oct 10, 2017
ask everywhere hard to find!
not a good idea, they are different types, the liquid is acid and it will cause alot of problems with the framework.
go to pride mobility site and lookup serial number finder
There is a latch under the seat, some are on the posts some ar in the middle some are on the side
Move the freewheel levers back and forth so the chair does not move drive position
red to red and black to black one of each color on each battery
check the user manual, is a great place to start
htttp://www.strege.com/BlueDoc
The batteries range from 160- 500 bucks, look in paperwork for correct size and call around for best prices
unplug the charger. Make sure your battery is good. Strege Mobility
you will need a off-board charger to charge the chair Strege Mobility
The chair charger needs to be unplugged and the freewheel lever put into drive position.
Strege Mobility
Batteries are not put in right. the charger is also bad. Strege Mobility
make sure cables are in properly or the chair won't do anything.
Strege Mobility
Jet 3 Ultra Power Chair Logo
417 questions posted
Top Jet Health & Beauty Experts
Colin Taylor
ray gallant
Norman Worley
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
Jet Health & Beauty
  • Jet Health & Beauty
Most Popular Question
when turn chair all comes top warning
  • Health & Beauty
