There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
SOURCE: I cant load the brads
You can go to http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
Click on Knowledge base and search for your model. I found it but I am unable to attach a copy here.
SOURCE: Need manual for stanley electric stapler model
here is a link to the manual
http://homeappliance.manualsonline.com/mdownloads/f2624d76-9579-4c12-a9f1-22eab6ac3388.pdf
SOURCE: I have a stanley TR150HL
If you use the picture that is posted as a reference, the staples are put into the gun by removing the bottom right- hand ( black insert)spring loaded slider. To describe it another way ..... when you hold the stapler in your hand , the staples go in the shoe bottom at the very rear of the gun. This is shown as the black indent at the back and bottom of gun. It is keyed in and is spring loaded ( to feed the staples) so don't be afraid to wiggle until you see how it is kept in the load trough. Good luck....hope this helped.
