Question about Stanley Tools & Hardware - Others
Disassembled the stapler now need diagram to reassemble
Stapler would not staple. Took it apart to see if there was a jammed staple. Now need a diagram to reassemble the stapler.
Posted by berad_61 on
  • 2 more comments
  • berad_61 Mar 15, 2009
    It is a Stanley TR100 Sharpshooter stapler
    I'll give them a call. Thanks for trying to help.
  • David Ford
    David Ford May 11, 2010
    What is the brand and model number and I will try and help
  • Anonymous Mar 14, 2014
    I have two staplers that seem to be jammed & I cannot figure out how to open them either. One is a Boston Ice StandUP Stapler & one is a PaperPro Prodigy stapler
David Ford
  • 2,176 Answers
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
Took apart my power shot 5700m because staple jammed and need a schematic diagram if you have one
there is no parts explosion that I have found for this tool on several different sites.
Jun 06, 2011 | Black & Decker 5700 Powershot Forward...
Got a staple jammed can't get out . don't know to take it apart.
This can happen all the time... first remove the slide-in tensioner which pushes against the staples. Remove the single bolt with lock nut which is towards the rear of the stapler. Now you can pivot the staple rail down and out of the gun. Just remove any twisted staples from the rail. Now reassemble the rail by positioning the front of the rail to go into the small slots in the front of the stapler body and re-attach the bolt. You may now reload the staples and tensioner and continue working. Takes just a minute or 2.
Jun 25, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
My craftsman easy fire stapler diagram
Mine stopped working last night. I took it apart and was able to reassemble it properly.
When both sides are rejoined the tip of the spring has to be inserted in the hole on the corresponding side (note red arrows on both pics)
This is a great stapler when it's working.
Nov 22, 2009 | Tools & Hardware - Others
Need help to reassemble Swingline Optima desk stapler
You must have purchased the Swingline Stapler that is actually a Paper Weight. Do you have the 747 model, the one the airplane of named after?
Sometime the imbeded PC fails, preventing the robotic controls to release the staple or to reassemble automatically.
Please return for a complete replacement and a free trip to Disey Lane just pay for transportation, tickets, lodging, food, shipping, packaging, and handling. Have a nice day and thanks for flying with us.
Sep 15, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
My swingline electric stapler model 42130 is jammed is there a manual release button the one on the back doesnt work
Taking the stapler apart is a complex task if you can figure how to do that.To dismantle the stapler, slide back the top, remove two small screws on both sides, six on the bottom, four of the screws are under the sticker so you must peel off the sticker, you must also remove the sticker on top. There two tiny shinny screws at the bottom once you are inside. Now you have access to more screws you can take off to get to the staples place where the jam is. Watch cables where they are plugged to in case they come off. If you are are a mechanical technician or technically inclined you might be able to fix this yourself but you must be very patient.
Aug 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Tools & Hardware - Others Logo
9,076 people viewed this question
Top Stanley Tools & Hardware - Others Experts
JOHN LAPIER
Paul Carew
Joe Garcia
Joe Garcia
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
