20 Most Recent Heavy Duty Stanley Bostich Heavy-duty Sharpshooter Electric Staple/nail Gun Questions & Answers
How do I load the stapler?
Search Results
    Stanley electric stapler/brad nailer - YouTube
    ? 5:06 https://www.youtube.com/watch?v=Zbgt2UXpS-M Dec 29, 2013 - Uploaded by Tindlez How to load staples and brad nails in Stanley electric staplermodel TREE550 ... Stanley SharpShooter Manual Staple and Brad Gun review ...
    Stanley Electric Staple/Nail Gun (TRE550) - YouTube
    ? 5:04 https://www.youtube.com/watch?v=6JTZJjQ3wlA Jan 5, 2015 - Uploaded by HowToWith GEO This video tests the Stanley electric stapler and nail gun. Model TRE550. This video will test both staples and brad type nails. ...Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. Unpack Guy 43,106 ...
    Safety Tips for an Electric Stapler : How to Load Staples into ...
    ? 1:01 https://www.youtube.com/watch?v=dMsdmYBoojU Feb 5, 2008 - Uploaded by expertvillage Learn how to load staples into an electric stapler in this free educational video ... Stanley Electric Staple/Nail Gun (TRE550) - Duration: 5:04.
1/28/2016 11:47:58 PM • Heavy Duty... • Answered on Jan 28, 2016
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
1/12/2015 9:58:09 AM • Heavy Duty... • Answered on Jan 12, 2015
My paslode air framing nailer
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
6/9/2011 2:54:36 PM • Heavy Duty... • Answered on Jun 09, 2011
My bostitch nail gun is
you need a new trigger assembly, there is a split o ring on the valve assembly.
12/22/2010 12:49:23 AM • Heavy Duty... • Answered on Dec 22, 2010
Just like my dad I figured I could fix it and
you might try going to bostitch.com and typing in your model number to see if they have a parts diagram, if not give me the model number and I will see what I can do.
12/30/2009 11:27:16 PM • Heavy Duty... • Answered on Dec 30, 2009
My bostich air gun is losing air out of the back
You need an end cap.
Thanks,
Jeff
6/24/2009 2:21:40 PM • Heavy Duty... • Answered on Jun 24, 2009
Bostich nail gun plumger not
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
12/26/2008 9:33:05 PM • Heavy Duty... • Answered on Dec 26, 2008
Instruction manual - Surebonder 5650 All In 1 Heavy Duty Staple Gun
Contact Surebonder for assistance using their form on their website. https://surebonder.com/pages/contact-us
3/22/2020 10:20:12 AM • Heavy Duty Tools... • Answered on Mar 22, 2020
EZ Squeeze 130 heavy duty stapler - feed bar
https://www.amazon.com/Bostitch-Squeeze-Stapler-Reduced-B8130/dp/B004I2MG1W
3/21/2020 9:26:28 AM • Heavy Duty Tools... • Answered on Mar 21, 2020
How do I adjust the depth the brads are counter sunk
There is a dial located by the business end of the Brad that adjusts the depth it fires. Also make sure you air pressure ( written on the stapler ) is set to level issued by the manufacturer. It'll say something like max pressure 90 psi. That would mean you will need to adjust the regulator pressure on your compressor to no more then 90 psi or to what ever number that is written on that sticker. Use a test piece of wood and turn the pressure down if you have no luck until you get the desired results.
4/24/2018 2:34:58 PM • Heavy Duty Tools... • Answered on Apr 24, 2018
How do you load a ace heavy duty clipper stapler model number 82?
I found some information here: ACE STAPLE Quality Tradition for Over 50 Years It takes the Clipper Undulated Heavy Duty 3/8" Staples. On the back of the stapler, there is a loading rod. Remove the loading rod and place a set of staples in the chamber, then re-install the loading rod.
12/5/2015 12:12:24 PM • Heavy Duty Tools... • Answered on Dec 05, 2015
Stanley tre500
8/28/2014 11:19:26 PM • Heavy Duty Tools... • Answered on Aug 28, 2014
Heavy Duty Stanley Bostich Heavy-duty Sharpshooter Electric Staple/nail Gun Logo
15 questions posted
Top Heavy Duty Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Heavy Duty Tools & Hardware - Others
Most Popular Question
just like dad figured could fix
  • Tools & Hardware - Others
