Televison & Video Logo
J
Jill Robinson Posted on Jul 07, 2017
Why bush TV flashing when I go into EPG to check programs and when in Recordings library?
1 Related Answer
rainbrowns3
BenjamineDupont
  • 465 Answers
  • Posted on Dec 12, 2016
SOURCE: EPG on recorder very very slow
You can use LEO Privacy to boost your phone, this is very useful for me.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Panasonic TV Orange flashing light meanings? Thanks
It means that an EPG timer recording has been set on the television. Check 'Timer Programming' in the Setup menu.
8answers
I can#t access the guideplus
Go to the hard disk setup menu.
Chose initiolized HDD, same as picture below.
Sometimes this can fix the problem.
Regarding the firmware, I do not think there is any firmware update available for download for this unit.
I did not find any download for your product.
Often, the image disk is distributed only to qualified repairers.
EPG WILL NOT WORK ON PHILIPS 42PFL9703 TV
Philips - Support Forum
www.philips.com/supportforum
PhilipsHere you can discuss all topics related to using Smart TV and Smart TV apps. Also find topics on IP-EPG, HbbTV, MHP, and Google Play store apps on Philips TVs Powered.... First of all JorisM, you're not the only one with this kind of Problem.Missing: 42pfl9703
No EPG data when using WEP EPG ' MediaPortal Forum
forum.team-mediaportal.com > ... > Electronic Program Guide > WebEPG
Jan 1, 2010 - Remote: Microsoft remote. TV: Philips 42pfl9703. TV - HTPC Connection: HDMI Hi, can use some help here. I can not get web EPG to work.
Powerscheduler shuts down PC too early during WEB EPG grabbing ...
Feb 8, 2010 - TV: Philips 42pfl9703 ... I found that data is loaded, but randomlystopped. ... EPG grabbing is busy, but still the system shuts down to early.
DVDR 7250H missing EPG problem - Philips - Digital Spy Forum
How to record on logik l24dvdb19
Buy a USB memory stick. Make sure it's a reasonably large one if you want to make a lot of recordings. Follow the manual instructions how to format it via the TV.
Use the EPG. Highlight the program to be recorded. Follow the onscreen directions.
How do I access a programme that I have recorded via epg using the original remote control. How do I set the time on my tv.
You don't mention the make and model of the TV, so it's not possible to give a specific answer.
The EPG is normally detailing the TV guide. I wouldn't expect to find my recorded programs listed in the EPG. There'll be a different way of accessing timer recordings. Check your user manual. Same for setting the time. It will be listed in the user manual.
Bush tv lcd32tv07hd
Usually if there is a guide or epg button on the remote control it will have digital freeview.
Bush btu250dtr
I have the same freeview and lost the peg after Wednesday the 13th November. To fix it, go to Menu - Set-up - Change your box settings - TV guide type & change to 8 day guide
2helpful
My Bush BTU160DTR has suddenly lost its EPG and shows no programme listings beyond Wednesday. Seems to link to end of TOP UP TV. How can I get it back please. We have 2 of these in the house.
Same with me but fixed. Change EPG to 8 day format. Instructions are here: http://www.avforums.com/threads/bush-btu160dtr-epg-problem.1269232/
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 • Cell Phones
Remote control slow to respond to Bush tv (LT42M1CFA)
Even though your TV s remote control emits infrared light, it might have not sufficiant frequency as it supposed to be. The fault with its resonator crystal inside the circuit board need replacement. It will look like this. Replace it with exact frequency marked on it.8_16_2012_4_53_50_pm.jpg
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
