Question about Philips Televison & Video
EPG WILL NOT WORK ON PHILIPS 42PFL9703 TV - Philips Televison & Video
Posted by Wayne on
Claude Kayser
    Top Expert:
  • Philips Master
  • 9,098 Answers
Philips - Support Forum
www.philips.com/supportforum
PhilipsHere you can discuss all topics related to using Smart TV and Smart TV apps. Also find topics on IP-EPG, HbbTV, MHP, and Google Play store apps on Philips TVs Powered.... First of all JorisM, you're not the only one with this kind of Problem.Missing: 42pfl9703
No EPG data when using WEP EPG ' MediaPortal Forum
forum.team-mediaportal.com > ... > Electronic Program Guide > WebEPG
Jan 1, 2010 - Remote: Microsoft remote. TV: Philips 42pfl9703. TV - HTPC Connection: HDMI Hi, can use some help here. I can not get web EPG to work.
Powerscheduler shuts down PC too early during WEB EPG grabbing ...
Feb 8, 2010 - TV: Philips 42pfl9703 ... I found that data is loaded, but randomlystopped. ... EPG grabbing is busy, but still the system shuts down to early.
DVDR 7250H missing EPG problem - Philips - Digital Spy Forum
Posted on Jan 30, 2016
How do I access a programme that I have recorded via epg using the original remote control. How do I set the time on my tv.
You don't mention the make and model of the TV, so it's not possible to give a specific answer.
The EPG is normally detailing the TV guide. I wouldn't expect to find my recorded programs listed in the EPG. There'll be a different way of accessing timer recordings. Check your user manual. Same for setting the time. It will be listed in the user manual.
Sep 04, 2014 | Televison & Video
On my sharp tu tv322h my epg is blank ive tried retuning but its still blank can you help?
This worked for me.....(from the Top Up TV website)
Purge VOD.
Press the menu button
Scroll down to Option 4 and press OK
Scroll down to Option 6 and press OK
In the help menu press 1397 on the remote control quickly and in sequence
Scroll down to the 'Purge VOD Schedule' option (next page) and press OK
Remember the DTR must be either on or left in standby at all times to receive the EPG and programme downloads. • The guide will update at the next scheduled slot (between 11am and 12pm daily).
Updates are also quicker if you change from 14 day EPG to the 8 day version...
Guide > Set-Up (4) > Change box settings (2) > TV guide type (9) > back arrow > Continue (green button)
Nov 20, 2013 | Sharp TUTV322H
My Bush BTU160DTR has suddenly lost its EPG and shows no programme listings beyond Wednesday. Seems to link to end of TOP UP TV. How can I get it back please. We have 2 of these in the house.
Same with me but fixed. Change EPG to 8 day format. Instructions are here: http://www.avforums.com/threads/bush-btu160dtr-epg-problem.1269232/
Nov 12, 2013 | Televison & Video
Can't get EPG to display after set up
johnandja460
You haven't specified which type equipment you are experiencing the problem. With our DISH Network receivers, if the EPG does not display you can do 1 of 2 things. First, unplug the receiver from the electrical outlet for 10 seconds and plug back in. This causes the receiver to reboot and re-acquire satellite signal. Then it will download the EPG.
If you still don't have the EPG, you can then run a check switch test. Press the Menu button on the remote. Main Menu will display on the TV screen. Press 6 (System Setup), 1 (Installation), and 1 (Point Dish) on the number pad. Highlight the Check Switch button on the right of the screen and press select. On the Installation Summary screen, highlight the Test button on the bottom left. Press select. The receiver will perform a switch installation check. After the test is completed, exit out of all screens till you are back to the TV screen. The receiver will acquire satellite signal and download the EPG. I hope this helps.
Ray Calo
DISH Network
Jan 19, 2011 | Sony Televison & Video
My jvc lt32de1bj TV has very slow loading epg. Is there a quick fix to speed it up
I'm afraid not. The loading of EPG programme tames is down to the TV transmissions. Some times you may hit lucky and find the EPG guide straight away, othertimes I have waited 5 minutes for a basic list!
Jan 02, 2011 | JVC Televison & Video
EPG on recorder very very slow
You need to upgrade the firmware on the recorder as this was the problem with my recorder. You may have to use the firmware for SH875M.
Nov 22, 2009 | Samsung Televison & Video
How do i retune my philips 42pfl5522d tv
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Sep 30, 2009 | Philips TV Tuner Video Capture PCI Card -...
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Nov 17, 2017 | Pinnacle Televison & Video
I want to retune Philips 32PW9576 / 05E
For specific model information visit http://tvretune.co.uk/productmanuals/
Nov 24, 2008 | Philips 19PS35S 19" TV
Humax pvr 9200T
Hello Fixya Team,
I did solve the problem with the EPG not updating quick enough when you power on.
If once you power on you switch channels to BBC1 youwill find the EPG updates quite quickly.
Hope this helps out.
Lomp.
May 31, 2008 | Humax Televison & Video
Televison & Video Logo
618 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
