Televison & Video Logo
A
Anonymous Posted on Sep 04, 2014
How do I access a programme that I have recorded via epg using the original remote control. How do I set the time on my tv.
Chris Frost
Level 3:
  • Master 985 Answers
  • Posted on Sep 08, 2014
Chris Frost
Master
Level 3:
Answers
985
Questions
0
Helped
218177
Points
3239
You don't mention the make and model of the TV, so it's not possible to give a specific answer.
The EPG is normally detailing the TV guide. I wouldn't expect to find my recorded programs listed in the EPG. There'll be a different way of accessing timer recordings. Check your user manual. Same for setting the time. It will be listed in the user manual.
5 Related Answers
A
Anonymous
  • Posted on Nov 08, 2008
SOURCE: SKY remote control programming
Try 065 - works for me on my universal remote.
Neciforo Llanto
  • 942 Answers
  • Posted on Jul 08, 2009
SOURCE: I can't control the volume. The TV seems to be
Hi...
If the remote is lost the TV have also a control look at your TV side by side there is any button there you need to reads where is the Volume control
Regards
PCmania
Anonymous
  • Posted on Dec 30, 2009
SOURCE: Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 27, 2010
SOURCE: I ordered a Toshiba DVR20KB
Hello
Hello
It is easy to copy to VHS. ou just go to the page 39 of the manual. It is described there.
NOTE:
During recording, recording will be paused when a signal
other than PAL or SECAM is detected. (See "Video Colour
System" on page 38 for details.)
• The signal from the external device will be output
automatically when the TV is connected to AV1 and the
external device is connected to AV2 using a Scart cable with
its power on. (However, it will not be output when this unit's
power is turned off.)
If you want to monitor this unit's signal, press [DISPLAY]
or turn the external device off. (The signal from this unit can
only be monitored during playback.)
If you want to monitor the signal from other input, press
[DISPLAY], then press [INPUT SELECTF] to select the
desired external input mode, then select the desired input
channel using [PROG.G\H].
Information on DV Dubbing
This function helps you to dub the contents in the DVC (digital
video camcorder) to DVD or VCR easily. (See page 71 for
DVC to VCR Dubbing.)
You can control basic operations of the DVC from the remote
control of this unit if the DVC is in video mode
Connect your DVC to the DV input jack on the
front panel using a DV cable. (Use the DV cable
that has 4-pin input jack and is compliance with
the IEEE 1394 standards.)
2 Press [INPUT SELECTF] repeatedly to select
the external input channel, then press
[PROG.G\H] repeatedly to select DV(AV3).
3 Press [DISPLAY] to display the DVC information
on the screen.
See the other instructions also. If you haven't its user manual. send your email address to me through Fixya. I'll send it to you as an attachemnt by return mail. OK.
Anonymous
  • 187 Answers
  • Posted on Aug 25, 2011
SOURCE: my original remote control has
TURN YOUR TV ON AND KEEP PRESSING THE POWER KEY TILL TV SHUTS OFF, THIS WILL FIND THE CODE, YOU'LL HAVE TO DO THE SAME FOR TUNING YOUR TV BACK ON TOO!
HOPE THIS HELPS!
How do I record a series on my new Bush recorder, which button on the remode control is it?
Usually to record a series the epg, electronic programme guide, needs to be open. Find the programme you want to record and highlight it using the navigation buttons on the remote.
Pressing the record button at this point will set the system to record the programme but if it is a series a window should open asking if you want to record the series.
There are usually two buttons coloured red. One red button will be in a line-up of four coloured buttons. The record button is generally the other one.
1helpful
On my sharp tu tv322h my epg is blank ive tried retuning but its still blank can you help?
This worked for me.....(from the Top Up TV website)
Purge VOD.
Press the menu button
Scroll down to Option 4 and press OK
Scroll down to Option 6 and press OK
In the help menu press 1397 on the remote control quickly and in sequence
Scroll down to the 'Purge VOD Schedule' option (next page) and press OK
Remember the DTR must be either on or left in standby at all times to receive the EPG and programme downloads. • The guide will update at the next scheduled slot (between 11am and 12pm daily).
Updates are also quicker if you change from 14 day EPG to the 8 day version...
Guide > Set-Up (4) > Change box settings (2) > TV guide type (9) > back arrow > Continue (green button)
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 • Cell Phones
1helpful
Remote control issues
If you whsh to get all functions operated with your TV, you must have its original remote control, and it is no doubt. No universal remote control will operate with all functions, that are supposed to be, especially to Sony Brands. You can buy the original remote control from the authorized service center for Sony, or from any authorized dealer for Sony. Then why do you go for an experiment
20helpful
Our Teac hdr2500t epg Guide stopped working showing only the programme times but not titles. This comes only a couple of days after it stopped allowing me to watch one programme while recording another...
Turn off the unit via the standby button on the remote and pick "passive standby". Next time you turn it on the epg will be back. The other option is to turn off the unit via the power switch at the rear of the unit.
2answers
EPG on recorder very very slow
You need to upgrade the firmware on the recorder as this was the problem with my recorder. You may have to use the firmware for SH875M.
4helpful
2answers
Any way to access on-screen menu on Sharp 13F-M50 without remote
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
3helpful
Just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
