SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: I cant make calls on my Kx-t7730 but i can recieve calls
sounds like you need to call a qualified tech
SOURCE: How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
SOURCE: dropped calls
Panasonic KX-TG9341T DECT 6.0 -
Both the BASE and the Handset DROPS OFF in the middle of a converstaion.... I CAN HEAR the Other Party talking, BUT they CANNOT HEAR ME... Very Strange...
