Do you have the book? it should show you how. if not take the pieces out that are loose and lay on a flat surface, now put together as if it is a puzzle, it will only fit one way. look to see if anything looks like it broke off rather than fell off. if nothing looks broken lift your machine up and lay on side so bobbin hole is facing up and see if you can lay the parts in as you put them on the table, if they don't snap into place look as see if maybe a small screw might have fallen out. hope this helps good luck.
