Powering on lights up power led immediately with one relay click then it goes through 3 sets of 2 relay clicks before 1 last relay click with power led still green. After, OPC and Power blink once together than 2 Power blinks before repeating. I did get the display to come back once by depressing keys when plugging in the power cord and it worked for several hours even powering off and back on. After powered off for more than an hour, it came up briefly before loosing the display and going back to the clicking and led light sequences. I cannot get it display again.
SOURCE: Display powers of with power up of AVC
Actually, I have heard about this kind of a problem before too.
Let me enquire more about it and I will let you know.
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
SOURCE: My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Testimonial: "Took a part back panels looking at the circuit board power capacitors, plugged in TV to power outlet, and powered up normally."
SOURCE: I have an aquios LC-42D64U which suddenly has the
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
