LG Flatron Ez T710BH 17" CRT Monitor TILT/SWIVEL & BACK COVER REMOVAL 1) Set the monitor face downward.2) Carefully remove the Tilt/Swivel by pulling it upward.3) Pressing the latch (b), Back cover by pushing it upward.4) Release the latch (c). (See Tip Spec.)5) Slide the Back Cover away from the Front Cabinet of the monitor.
Hi milsyr, 1. switch on the printer 2. Lift the blue/gray latch on the cartridge carrier and remove the cartridges you need to replace. 3. Remove the pink tape from the new cartridge.Hold the cartrige so the label is face forward,and the words are facing you. 4. Slide the new cartridges into the print carriage. - The color cartridge goes into the left side of the carriage and the black cartridge into the right side of the carriage. 5. See that you slide the cartridge underneath the metal bar and then push it down into place with your fingers. 6. Close the cover on top of the cartridges and make sure the latch is secure. 7. Close the printer carriage door. 8. Press ok on the front of your printer. - An alignment print will follow.
Turn the mouse over so the back is facing upward, then slide the power switch to the "off" position.
Place the mouse on its back and slide the battery cover off the front of the mouse with your thumb.
Remove the old batteries by sliding them out of the battery holder.
Slide two fresh AA batteries into the battery holder. Make sure you orient the batteries with the positive sides facing the plus signs and negative sides facing the minus signs.
5
Slide the battery cover back into position until it snaps into place.
6
Slide the power switch on the bottom of the mouse to the "on" position to resume use.
You need to open top cover. Find lock you need to press that lock so upper cover is faced off. You can find that lock on the front middle side. You need to press it so uper cover is up then pull ink cartridges from it. Then reattach new cartridge. Let me know if you need further assistance. Thanks for using FixYa.
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Turn the computer off.
Disconnect the power-cord.
Remove the side-covers.
Disconnect the "data" and the "power" cables from the back of the drive.
Look for screws on both sides of the DVD drive.
If there are any, unscrew them, and the DVD drive will slide out the front of the front face-plate.
If there are no screws, remove the front face-plate from the computer.
Then, squeeze the "drive-rails" on the sides of the DVD drive, to "unlock" it, and gently pull the drive out.
Reverse the wholel process to install the new DVD-drive.
You need to take off the face of the computer. There are six plastic tabs inside the computer that you can press down to remove the face. Once it's off, you can slide the drive out the front.
Let me know if you have any other questions. I'll monitor this thread.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
OK, solved it now, you need to remove the front instrument panel first. This is held in place by four plastic lugs, two top and two bottom, which you can see when you remove the top of the machine. It's a bit fiddly since you don't want to break the lugs but a bit of patience gets it off clean. Next remove the two pipes that supply hot and cold water from the rear of the dispenser and also another pipe which fits onto the side. There are three small nuts to remove that secure the unit to the front of the machine and then by pushing it backwards and too the side it will slide out easily. Lastly there is a pipe to remove underneath the unit and then it is clear. Simply reverse the process to fit a new unit.
