SOURCE: pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
SOURCE: printer pauses between each print job
Step one: Download and install the print diagnostic utility. click on this link from HP and download the printer diagnostic link. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?swlinkmsg=100&lc=en&dlc=en&cc=us&product=1153494
SOURCE: I'm using tally 7.2, while printing cheque font
to increase the font size in the printing cheque is just simple go on to (or) press F!! key on the cheque printing option will available on there on the give yes . and then some kind of list will available on there on the list read the sentence one by one the font increasing size is available on there give the correct font size as a number for example (60)
SOURCE: Stops printing after sending job
try to reset to factory defult,
run calibration and sensor profile.
if dont help,
it is possible that the power suply or logic board is faulty.
SOURCE: CHEQUE PRINTING CONFIGURATION IN CANON LBP3300
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size
or page setup when printing from an application, taking Adobe Reader 6.0
as an example.
Note:
The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note:
The printer name displayed in this dialog box can be
changed in the [Printers and Faxes] folder (the [Printers] folder for
Windows 98/Me/2000).
