20 Most Recent Tally T6218 Matrix Printer Questions & Answers
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
Tally T6218... | Answered on Mar 17, 2018
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Tally T6218... | Answered on Mar 18, 2016
The power supplies are known for shutting the printer down without any error if that is the symptom, replace the power supply.
TALLYGEN 084435 POWER SUPPLY ASSY T6218 Refurbished
If not let me know exactly what it is doing.
Tally T6218... | Answered on Dec 28, 2015
Usually that is something wrong with the hammer bank
MRP provides IT Parts Product Supplies and Services
In rare instances it can be cabling, power distribution PCB or the main logic.
Tally T6218... | Answered on Jul 17, 2015
please follow these notes to calibrate the paper out sensor.
Tally T6218... | Answered on Jan 06, 2015
can u sent me the backup i can solve the problem.. Tally velu - sree sai solutions 9789495543
Tally T6218... | Answered on Oct 18, 2013
If the printer is showing "CONFIG 1*" this is not an error, this message is simply advising that Menu CONFIGuration 1 is selected hence the * beside the message.
Assuming the settings in CONFIG Menu 1 are correct if you send data to the printer in the correct format it should print.
Tally T6218... | Answered on May 22, 2013
you need to clean paper motion sensor first,
check its connection on logic board
clean the connector of sensor,
if you can then please post u r problems with printer model then i can explain it more.
Tally T6218... | Answered on Jun 05, 2012
you need to check logic board.
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
Tally T6218... | Answered on Jan 11, 2012
check the logic board if not one of the coils is faulty
Tally T6218... | Answered on Oct 18, 2011
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Tally T6218... | Answered on Oct 15, 2011
Tally T6218 Matrix Printer Logo
100 questions posted
Top Tally Office Equipment & Supplies Experts
Alexey Krenvalk
Alexey Krenvalk
Computer Links
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
tally printer error some times hammer
  • Office Equipment & Supplies
