Question about Tally T2245 Matrix Printer
Suggest a solution for Tally.ERP\9\Data\TranMgr.900 error
Posted by suneil_pradh on
sathiasabarn
    New Friend:
Have eror 'H:\tally9\11-12\10006\tranmgr.'
size 2180096
Position:2182144
chars 512 (done 0)
so i can not add new data please solve this problem.
Posted on Jan 23, 2013
kingtr2011
    New Friend:
Posted on Jul 05, 2011
KalimG Khan
    New Friend:
Mukesh Choudhary
    New Friend:
. First of all take the back up of tally data
2. Create a new folder under Data and rename with 5 digit number (Like 10002)
3. Copy the following files from corrupted data folder to newly created folder
Company.900
Linkmgr.900
Manager.900
Tranmgr.900
Cmpsave.900
4. Then go to run and execute the below command
C:\Tally.ERP9\tally.exe data 0
5. Then press Ctrl+Alt+R and click on YES at confirmation box. Then wait for complete the process
Posted on Jul 18, 2015
  • 4 more comments
  • B KAUR
    B KAUR Mar 03, 2018
    thanks sir it was really helpful
  • Anonymous Apr 13, 2018
    I tried this but not working, Could you please help me
  • Techpro Computers
    Techpro Computers Apr 19, 2018
    too good u r worked for me
  • Tuleshwar Sahu
    Tuleshwar Sahu Jun 04, 2018
    my tally is tally 9 not a erp 9.i try your trick but its not work.pls heal me.
  • Asim Makkani
    Asim Makkani Dec 31, 2018
    It worked for me.....Thank you.
  • Paresh Gajera
    Paresh Gajera Mar 07, 2020
    tray it but not work
Paresh Gajera
    Welcome Back:
    Visited the website for 2 consecutive days.
When i tray to revrite data than get error
Error
Exiting Tally!
Have eror 'f:\tally9\11-12\10006\tranmgr.900'
size 94575104
Position:94575104
chars 512 (done 0)
so i can not complate process please solve it...
Posted on Mar 07, 2020
Cogniscient Business Solution
    Habit-Forming:
    New Friend:
  • 3 Answers
The interface is user-friendly and allows all aspects of your business to be managed through one ERP solution. It helps your business to be more productive in sales, accounts and become more responsive and to gain better insights.
Learn More: https://www.cogniscient.in/
Posted on Sep 24, 2019
SATHYA
    New Friend:
Error
Exiting Tally!
size 94575104
Position:94575104
chars 512 (done 0)
Posted on Mar 17, 2017
Unable to create company path c\tally.erp 9\Data\10005
Does your user name and password have administrative rights on the computer? If not then you may need try with a user that does. I have run into some software that will throw a similar error if the folder already exists.
Jun 26, 2015 | Tally Office Equipment & Supplies
Tally file damage error
Open windows Run
Enter C:\TALLY\tally.exe C:\TALLY\DATA 38528
it will open Tally now press Ctrl+Alt+R
it will ask to rewrite company.... after rewrite check your problem will get resolved.
for more details visit www.tallyworld.com
Tally ERP 9 Tally 9 ERP Software the complete business accounting...
Mar 30, 2014 | Office Equipment & Supplies
When i m migrate tally72 data to tally erp 9 data then show the message migration is unable to reach tally.ERP 9 server post request failed
go to data folder of tally
rename the new data 10000 to 10000n
open tally erp 9 crack version
on select company press ctrl+alt + r
your new data will not b showing
than open tally data folder again and change the name of folder from 10000n to 10000
than press again ctrl+ alt +R
now in list you will be shown with new data
press enter
the data will be rewrite in older version
Oct 06, 2013 | Great Star Software Technology R Tally...
How do I correct error code 2147483650?
To fix this, follow the steps below:
1. Back up your Tally data.
2. Make a new folder under the Data and then change the name of the folder with a 5-digit number such as 11111.
3. Copy the files below from the corrupted folder to your folder 11111.
Company.900, Linkmgr.900, Manager.900, Tranmgr.900 and Camsave.900
4. Click Start and then Run and then type the command C:\Tally.ERP9\tally.exe data 0.
5. Press Ctrl+Alt+R and click Yes to confirm. Wait until the process is done.
6. Exit Tally and re-open it to see if the problem has been resolved.
Alternatively, if the above steps didn't work for you, remove Tally and all its components completely. And then restart your computer and reinstall it again to replace all the corrupted files.
Mar 29, 2013 | Office Equipment & Supplies
When i migrate tally7.2 data to tally erp9 error occur migration is unable to reach tally erp9 server
This Error with migration of data occurs when the connectivity is not proper with the Tally ERP ODBC. It includes the IP:Port.
The Default port for Tally ERP is 9090.
To change the port go to the installed tally ERP 9 folder. Click on Tally file type Configuration Settings, open it with a text Editor i.e. Notepad. Somewhere at the bottom will be ServerPort. Change the ServerPort to 9090. The migration will work. I have tested. Works fine with me.
Apr 26, 2012 | Computers & Internet
HEN I WAS OPENING TALLY ERP 9 I HAVE BEEN FACING
Step 1
Windows Key+R
in the Run Box
Type your Tally Folder Path as following
Eg. D:\Tally.erp9\tally.exe data 0
when open Tally Getway
use Ctr+Alt+R
Rewrite All Company
Enjoy....
IF Problem is same
then in the data folder company number folder
delete all tsf file and attem step 1 again
Problem is 100% solved.
AYS, Beawar,
Thanks to Mir -- Manish JI Garg..
Mar 26, 2010 | Tally LA650 Matrix Printer
I have eror c:\tally\data\30000\tran.mgr.900
i have an error D:\tally9\DATA\10005\tranmgr.900
size 19817472
position 19817472
chars 512(done0)
i can't rewrite my dat
Apr 25, 2009 | Computers & Internet
Tally T2245 Matrix Printer Logo
18,686 people viewed this question
Top Tally Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Lee Hodgson
Lee Hodgson
Roy May
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
