SOURCE: Connecting Lenovo Tablet to Sony XBR TV
Hi swampole,
You'll need to purchase a Sony Location Free base station and software (included). Try this link:
http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog?storeId=10151&langId=-1&catalogId=10551&in_dim_search=&keyword=location+free&gobutton.x=0&gobutton.y=0
The Sony Location Free base station can transmit your TV, or most any video signal for that matter, to your laptop as long as it has the Location Free software installed, wi-fi capability, and is within range. It can also transmit your programming over the web so you can watch via broadband and not even need to be home! The only drawback I have experienced is that if the signal is not strong enough, there is a choppiness to the video stream (not unlike watching videos online sometimes), and there is a 4 second delay due to encryption/decryption, but this really does not matter if you're not watching a "live" feed.
I have installed these units for clients and use one as well from time to time to watch TV from rooms without one. Good luck and hope this helps!
Jeff
SOURCE: how do I get my RCA 27
You did not mention which input you attached the RCA cables to. If it was component it would be one selection, if it was composite it would be another. If you do not have your operations manual you can find the manual at http://www.retrevo.com/samples/RCA-TV-manuals.html Download it and starting on page 7 look at the diagrams they show for hooking up the DVD. Inspect your hookup and make sure it is correct. If it is then follow the procedure they give for selecting the device. Using this manual you should be able to sort out your problems. This unit has quite a few inputs but they all should be available on the menu. I suspect that you are looking at the wrong one. Get the manual and look at the pages that I mentioned. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
