20 Most Recent Lenovo 3000 N100 Notebook Questions & Answers
hi.
it sounds as if its over heating.
the first thing you should check is to make sure the fan is running and even if it is try to clean out the fan.
or it could be that it needs the cpu heatsink paste replacing.
go to this link this will show you how to do it. How to Apply Thermal Paste .
all this is not to say thats what it could be,its just to say it might be the fault.
Lenovo 3000 N100... | Answered on Nov 02, 2017
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Lenovo 3000 N100... | Answered on Mar 13, 2017
how to download webcam driver for lenovo 3000 n100 for win 7
Lenovo 3000 N100... | Answered on Mar 24, 2016
Press Ctrl and Prnt at the same time and paste into your document writer.
Lenovo 3000 N100... | Answered on Jun 22, 2015
Does the battery hold charge for long?
THe flashing means not charging..
test another power adapter or change battery
Lenovo 3000 N100... | Answered on Jan 02, 2015
download BT softwere and instal it,,,,,,is man kon si badi bat hay,,,
Lenovo 3000 N100... | Answered on Nov 15, 2014
pick up that key wich is not working.and then cleen the ruber sid and fix the key ,,,,,if not work then change the key board
The BIOS password was set by the owner of the laptop. There is no crack as such.
Lenovo 3000 N100... | Answered on Apr 21, 2014
Function (Fn) + F5 keys AT SAME TIME.
Lenovo 3000 N100... | Answered on Mar 14, 2014
Hi Janis552,
Thank you for bringing the problem to my attention. Sounds like the the particular keys you mentioned is not working anymore. One way to test the issue is to log to the BIOS menu. Turn off the computer and wait for 10 secs. Turn on the computer and keep on tapping F1 or F2 to go to BIOS menu. Once you are inside the Bios menu test the keys that you mentioned if they will react. If there is no reaction to the keys then the problem is the keyboard itself. You need to repalce the keyboard. You may call Lenovo tehc support at 18774536686
Thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo 3000 N100... | Answered on Nov 19, 2013
Download Connectivity Hotspot Software, its a charm to have it. Worked on my HP G72, and the speed is great as well.
Lenovo 3000 N100... | Answered on Jul 04, 2013
i haven't any bluetooth confuguration in my laptop so what can i do ?
Lenovo 3000 N100... | Answered on May 06, 2013
check device manager if there are drivers that were not properly installed, usually with (!) symbols or reinstall drivers using vista drivers.
http://support.lenovo.com/en_US/detail.page?LegacyDocID=migr-63572
navigate down to the modem/bluetooth drivers, try to use VISTA drivers.
Lenovo 3000 N100... | Answered on Apr 01, 2013
Check to see that the laptop has a Bluetooth adapter installed. Click on the "Start" menu in the lower-left corner of the desktop. Click on "Control Panel." Click on "Performance and Maintenance" and then on "System." Click the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Look for a small blue icon that says "Bluetooth Devices." Click on the "+" next to it to expand the menu. There should be at least one Bluetooth device listed. This indicates that your laptop has a Bluetooth adapter. Turn on the Bluetooth device by locating the physical or software switch that activates the adapter. Check the outside edge of the laptop for a button or switch that is labeled "Bluetooth," shows a picture of the Bluetooth icon or is labeled "Wireless." Turn this to the "On" position. If no physical switch exists, check the function keys on top of the keyboard. Look for one that shows a wireless symbol. This may look like a small antenna with waves radiating out from the top. Hold down the "Fn" or "Function" button and press the corresponding function key until the computer indicates that Bluetooth is turned on. Locate the Bluetooth icon in the system tray in the lower-right corner of the desktop. It will match the appearance of the Bluetooth icon you located in the Device Manager. It may have a red symbol in the center that indicates that the Bluetooth is turned off. Right-click on this icon and choose "Start the Bluetooth Device" from the menu. Test the Bluetooth by connecting a Bluetooth device. Right-click on the Bluetooth icon in the system tray. Use the "Quick Connect" option or follow the Bluetooth setup wizard accessed through the "Add a Bluetooth Device" option. Hope this helps.
b>
Lenovo 3000 N100... | Answered on Dec 13, 2012
I don't follow your assumption. Not unless you didn't have Vista 64-bit originally, and have installed it.
Driver: Small piece of software that allows the Operating System, to communicate with a device
However;
Lenovo Support > Lenovo 3000 N100 Notebook PC > Drivers download page,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-63572
My thinking is the laptop is dirty inside.
Air cools the hardware components inside the laptop.
The cooling fan draws air from the Bottom of the laptop.
Dust, dirt, hair, lint, food crumbs,....you name it; is drawn in.
The Processor and graphics chipset, are the two hardware components that give off the most heat.
When a Processor overheats, it turns off. (BIOS turns it off)
This is a fail safe feature built in.
Keeps the Processor from burning up.
ALL power removed, (AC adapter {Charger}, and Battery), and blow-ing air in the intake port, (Fan opening), will NOT repair.
At most it is a temporary repair. Kind of like putting a Bandaid on a hole in a dam.
Laptop needs to be partially disassembled, and Q-tips, soft small brush, (Old makeup brush?), plus a can of compressed air for computers; needs to be used.
http://www.youtube.com/watch?v=AkAeE5I5E_A
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Click on the bold black subheading - Hardware maintenance manuals
It is a Service Manual in PDF file form.
http://www.youtube.com/watch?v=JQRAjlUYL90
Also remove the Ram Memory module/s ('Stick'), and clean the gold plated contact pins, with a pencil eraser. Use air to remove the eraser dust, reinstall.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Lenovo 3000 N100... | Answered on Nov 25, 2012
What I could recon from your question is that your Bluetooth driver is not installed in your PC7.
Please be informed that any Driver software depends upon the hardware make and Operating System. So, you need to know all these information's to do get going.
Please find the Driver software's of your Bluetooth inside the installation disk provided with the System at the time of purchase. In case if you do not posses the same then you need to download the driver software from the web. As you have not mentioned your PC Model No. and Operating System you are using, I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the PC(Lenovo).
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Webcam Model number and the OS that you are using.
After you have downloaded the driver, Double click on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
Lenovo 3000 N100... | Answered on Oct 05, 2012
Lenovo 3000 N100 Notebook Logo
183 questions posted
Top Lenovo Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
3000 Lenovo
  • 3000 Lenovo
Most Popular Question
start bluetooth in lenovo laptop
  • Computers & Internet
