m
michael samawi Posted on Feb 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roll of paper 270gsm size 355mm weight 1000kg how many meters
Geoff White
Level 3:
  • Office Equip... Master 1,948 Answers
  • Posted on Feb 16, 2017
Geoff White
Level 3:
Answers
1948
Questions
Helped
388251
Points
7024
It has 270 gsm and weighs 1000 kg, so the paper area is
( 1000 * 1000 ) / 270 = 3703.7 sq m
and it is 355 mm (wide I presume)
so length is 3703 / (355 / 1000 ) = 10432.9 m
Xerox error code 024-958
  • Description: MSI Paper Size Mismatch Cause: The size of paper in the MSI does not match the specified print size.
  • Remedy: 1. Open/close Tray, or reseat paper on manual feed tray. 2. Use the paper that meets the specifications. 3. Make sure that you are using the correct printer driver. 4. Check the Paper Size and Paper Type of the Tray Setting menu on the printer operator panel and the printer driver. 5. If the problem cannot be solved, replace the corresponding paper feed rolls. • MSI FEED ROLL / NUDGER ROLL (PL 2.6 MSI) • MSI RETARD ROLL (PL 2.7 Bypass Tray) • RUBBER ROLL ASSEMBLY (PL 2.2 Transport Assembly) • REGI PINCHROLL ASSEMBLY (PL 2.2 Transport Assembly) • REGI PINCH ROLL (PL 2.2 Transport Assembly)
1helpful
2answers
I have a 2010 Lancia Musa 1.4t. How much weight can I tow?
Most towing advise works to the 85% rule. As long as the maximum weight to be towed is 'Not' greater than 85% of the vehicles maximum 'kerb' weight, (maximum gross weight).
The Musa should not pull over 1000kg, (1 metric tonne). A braked trailer will allow that weight to rise by about 200kg.
What size paper roll is used for TI 5045sv? Can't seem to find it anywhere!
Standard 2-1/4 inch wide plain paper single copy calculator paper rolls, available at Office Depot, Reliable Office Supplies, and many other office supply stores and catalogs. Probably have them at Staples, too.
The paper drawer is stuck on my new Samsung CLP 310
Turn the printer off. Unplug it completely. Very Carefully, roll the printer onto one side. Push the paper drawer in as far as possible, then, by grabbing the bottom of the paper drawer, and the front of the drawer with your opposing hand, slowing slide the drawer to release the pressure and slide it out at the same time. Pressure from the rollers pulling paper from the drawer will jam the paper between the drawer so tightly that the weight of the machine will act as a clamp. When your remove the weight of the machine by rolling it on it's side, you can slide the drawer out easier.
What is 230 microns in gsm?
230 microns is thickness of paper. gsm- grams per square meter is weight of paper per size, so varies even if remains at 230 microns, you need to stipulate paper size
4helpful
2answers
Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
3answers
Auto sheet feeder fault
he paper’s weight may be expressed on a different basis than the paper used to rate the printer’s capabilities. For example, a 20-pound bond paper equates to 28 pounds cover and 42 pounds index papers in thickness. The differences among bases stem from the sizes of the large sheets from which the paper was cut. For example, Sharp says, bond paper’s weight is determined by 500 sheets of 17- x 22-inch stock (later sectioned into 8.5- x 11-inch reams), whereas index paper’s weight stems from 500 sheets of 25.5- x 30.5-inch paper.
Match the basis for the weight of the paper to the basis of the printer’s maximum paper weight rating. If the printer was rated on only one basis, such as cover or index, and your paper ****’s wrapper only lists the paper’s weight by another basis, such as bond.
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
k24674
ADMIN Andrew
ADMIN Andrew
