Intex bubble spa with E90 code
SOURCE: i had boughten a intex pool from a garage sale and
if it has hose clamps tighten them if the area that is leaking has o rings (they can become brittle and leak water) you can purchase them at local harware store
If it is a cracked housing they can be purchased at intex.com
call them up and order your parts
SOURCE: error 6 thermal cut out keeps turning the spa off
Check for proper water flow and disassemble any bypass governor and inspect for blockage
SOURCE: I've been reading the blogs and have ascertained
You have about 8588 gallons of water in your pool ... One inch of water contains about 159 gallons in your pool. You should consider a 6 hour turn over rate. I recommend a high rate sand filter with at a minimum 1.5 sq feet of filter area. You need to move about 24 gallons a minute to achieve the 6 hour turn over rate.
Continue your research with these figures at hand.
Thanks for your interest in FixYa.com. If you found this information helpful, please vote ...
Testimonial: "Thank you for the information - very helpful"
SOURCE: Pool Pump - keeps getting air
It sounds like you might not be getting enough suction on your pool filter. I would check all of the hose connections for cracks, loose fittings, etc. If you are getting any extra air, it will cause your pressure to decrease.
SOURCE: filter pump running hot and water is not
If your pool filter and pump are running not and not circulating, it sounds like either your pump is not primed properly, you have an impeller jammed/or broken, or you have something clogging the hose to the return line that is causing pressure to build up. Check all three of these and bet you will find your problem.
