20 Most Recent Dream Maker Spas Dream Maker Ez Spa Hot Tub Questions & Answers
Is the motor cycling on and off?
Is the braker tripping after two minutes?
Dream Maker Spas... | Answered on Jul 07, 2018
not too familiar with that brand but check all fuses with ohm meter
Dream Maker Spas... | Answered on May 08, 2018
An electrical supply house would have, or could get your fuse. You can also contact Dream Maker and they would send one to you. It sounds like the you have a voltage issue and may pertain to other fixtures you have on the circuit (such as freezers). If you have the spa plugged into an extension cord, this will likely be the cause. You need to have an electrician run a dedicated 15 amp service to the spa.
Dream Maker Spas... | Answered on Apr 21, 2018
check recirculation pump if ok check heater element and pressure switch and temp sensor also see if locked
Dream Maker Spas... | Answered on Jan 30, 2018
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
if pumps ok check temp sensor
Dream Maker Spas... | Answered on Jan 06, 2018
bad recirculation pump and possible heater
Dream Maker Spas... | Answered on Dec 05, 2017
check fuses inside power box inside if blown check recirculation pump and heater
same size flex hose from hardware store
check recirculation pump and heater element and temp sensor
or plastic coupler
check fuse inside power box of unit if blown check recirculation pump and heater element
pump seals if so replace pump or possible hose crack on plastic
check fuses inside power box maybe wet if blown check recirculation pump and heater element
drawing current check recirculation pump and heater
check wiring 120 volt or 220 volt
Dream Maker Spas... | Answered on Nov 30, 2017
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
455 questions posted
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Dream Maker Spas Pool & Spa
Most Popular Question
spa shut off keeps overheating
  • Pool & Spa
