Ignition is locked out unit will not fire
Turn it off at the black toggle switch inside the front panel or turn it off at the breaker for 2-3 minutes
Then try again.
Check that flow is good, gas is on ect...
Is it saying lockout on the display?
If not then as you fire it up after cutting power keep the panel off and watch the ignition control red diagnostic light.
The blinking sequence of that light should point you in the right direction. There is typically a label that will tell you what the blinks mean.
Minimax nt heaters are on borrowed time, and in most my Delong with them once they start having an issue it will never end , basically they are lemons and replacements for them is very common
