Tools & Hardware - Others Logo
joseph_juber Posted on Nov 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installing a shower base floor
If the floor is slooped do I still need to mortar it before I nail down the base?
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
  • Posted on Nov 18, 2016
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2700613
Points
29284
If you don't want to have drainage problems with the pan, the floor should be level.
2answers
How to tile a floor
Billy, Click on and read the links provided to learn how to tile a floor.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://novafloor.us/installation-guides
http://novafloor.us/wp-content/uploads/2014/09/Installation-Guidelines-for-Direct-Glue-Tile_Grout-v2-10_2015.pdf
http://novalis-intl.us/wp-content/uploads/2012/10/LUXURY-VINYL-TILE-INSTALLATION-GUIDE.pdf
tip
How to Install a Bathtub
Anyone can install a water bathtub, but to do it right so that it will last a lifetime takes some time to make sure that it is installed properly. If installed correctly the bathtub you install will be well supported and will not experience the stress that ones that are not installed properly will experience.
The first part is to make sure that the space is exactly the same size as the tub or tub/shower unit. Leave the end wall out till the unit is in place and then fasten it in place.
If you take the time to notch out for the lip on the tub or the tub/shower unit, your dry wall will not have to bow out over it. Place the unit in place and mark the studs, then chisel out ¼” deep so that the tub sits back and the lip is flush with the face of the studs.
Once you have the unit “fitted” exactly to the space, you are then ready to install the bathtub or tub/shower unit. By this I mean that I “set” the unit in a bed of mortar to make sure that the bottom of the unit and the unit it’s self cannot possible move or flex when weight is in it. To do this you need to make a bed to set the tub into.
Depending on the size of the unit, usually one bag of mortar mix will be sufficient for one fixture. Mix the water with the mix right before you are ready to set the unit. Make sure that the mix is stiff enough so that when you place it on a pile it will stay and not run. Now place the mortar in the center under where the unit will set. Place a sufficient amount so that you will have to press down on the unit to “set” it into the mortar.
Carefully place the unit in place and gently press it into the mortar until it is sitting level. You can now place a couple of screws into the lip to hold it in place until the mortar gets hard. After a few hours the mortar will be hard and will fully support your unit. The bottom of the unit will not be able to flex at all and your unit will be on the road to outlasting you!
You can now finish the remaining wall, then trim the unit and finish the walls. Plumbing can now be installed. Remember to provide access to the plumbing just in case of future problems.
on Feb 27, 2010 • Plumbing
Maax shower base installation
I would just cut enough to install the pan by the way does the drain line hook to this pan? that will give it support as wwell
Apr 30, 2014 • Plumbing
I would loike to remove my bottom nailinf fin on my pella replacment window
should not be a huge issue to trim off the bottom nailer... trim off with a razor knife being careful not to penetrate the frame. the primary concern is providing support to the frame. Using mortar and wood shims, layer mortar where the window will sit and level it using the wood shims, leaving space to remove the shims after the mortar sets... I'd recommend using screws to afix the remaining fins to the studs to lessen the loss of mortar from shifting the window during install
~~~~] shim [~~~~mortar~~~~] shim [~~~
FRONT PANEL SKIRT SITS 3" LOWER THEN BASE OF TUB DO I NEED TO INSTALL 3" OF MORTAR
You need to install whatever will function best to get the skirt raised up to match.
Rod
US Parts Center
888-521-6183
1helpful
Some years ago I purchased and installed a MAAX shower stall. After installation, it developed squeeks in the floor. I have identified that the squeeks are eminating from the aspenite that was attached to...
Hello. When you say basement side, I assume you are referring to the underneath. There are a number of options available, all hinge on the conditions you have.
1) Plenty Of Room: The best scenario. You can install a solid cross brace (preferably the same material as your joists) across spanning from one joist to another under the seam. Nail (best method - due to ability to handle potential shear stresses) cross brace in as secure as possible to the floor boards. Once that is done, lightly drive in a shim or two coated both sides with a little (this stuff goes a long way!) construction adhesive.
2) Same as Above, But Pipes Run Through: Either use a solid cross brace that will fit (ie 2x3) and treat the same as above, or use the 2x2 method where they are installed diagonally, but directly underneath the seam and shim. This should remove most of the squeak.
3) Not So Much Room, But Still Workable: (ie no pipes but limited access) Build an "H" frame that will span between joists, and the cross piece will do the same as #1. Secure in any manner you can, but ensure that it is secure on both sides of each support. Then shim and glue.
4) Can't Cross Brace: Not the greatest solution, but sometimes necessary. This one depends solely on the knowledge you have of the materials used... specifically their thickness'. Cut a piece of 5/8 inch (3/4 inch is better) plywood that will fit into the beam spaces under the seam. Be sure that they span about 6 to 8 inch on either side of the seam using screws (prefferably the kind meant for wet applications). NOTE: some shower bases are installed on a concrete/thin-set curb, this means that the screws must not penetrate the sub floor OSB. So, if your flooring material is only 5/8 inch, your overall screw length should not exceed 5/8 plus material used. (ie 5/8 + 5/8 is 1 and 1/4 inch maximum. Ideally 1 inch only) After all we only want the screws to hold. Before securing the brace, spread a good construction adhesive on it (I am a big fan of PL Premium).
If you are referring to the other side of a wall, and the shower is on the lowest level, there isn't much available in my experience. I have seen some similar issues involve: removing the silicone around the base and securing that. This involves drilling some of the material out on one side of the seam, filling with a two part epoxy, using heavy weights to secure the floor down, and shaping the epoxy smooth so the caulking will cover. This never does the job completely as access to the seam is limited.
These methods are a few suggestions that should help the issue. If they help out, please rate this answer a four thumbs-up. Thank you and good luck.
2helpful
2answers
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
What do I use and how do I keep the shower base level.
Hi, As with most shower trays, you must bed the tray down onto a suitable floor ( ie; solid and dry) surface using a bedding down mixture. Weak mix sand and cement is ideal for this purpose. Mix sand and cement at a ratio of about 5 or 6 to 1 and spread out on to the area where the tray is going. NOTE: it is important that the mixture is spread out evenly and touches all of the underside of the tray. Make sure you seal the floor a day before using a water and PVA glue sealant mixture so that the mortar will stick. Tap down the tray BY HAND or by using your fist, and use a spirit level on all four edges until the tray is completely level ( or as near as you can get it) I have provided a link for you with the full installation instructions. Hope this was of help to you.
http://www.americh.com/site/index.php?option=com_docman&task=cat_view&gid=19&Itemid=12
My newly installed tub pops like an oil can when I step into it for my shower. The tub was installed according to the instructions, with a strainer on the wall and no bedding. What can I do to make it...
not sure what an 'oil can' sound is... but ... if it is popping and creaking when you step into the shower then the base is not properly supported. there is a a gap or two between your floor and the base of the shower floor.
2answers
5/8 flooring nailer
the base plate may be shimmed, but that unit was designed for 1/2" and 3/4" however, the Bostitch MFN201 Manual Flooring Cleat Nailer Kit will install 1/2"- 5/8" & 3/4"
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
