As with most shower trays, you must bed the tray down onto a suitable floor ( ie; solid and dry) surface using a bedding down mixture.
Weak mix sand and cement is ideal for this purpose.
Mix sand and cement at a ratio of about 5 or 6 to 1 and spread out on to the area where the tray is going. NOTE: it is important that the mixture is spread out evenly and touches all of the underside of the tray.
Make sure you seal the floor a day before using a water and PVA glue sealant mixture so that the mortar will stick.
Tap down the tray BY HAND or by using your fist, and use a spirit level on all four edges until the tray is completely level ( or as near as you can get it)
I have provided a link for you with the full installation instructions.
Hope this was of help to you.
http://www.americh.com/site/index.php?option=com_docman&task=cat_view&gid=19&Itemid=12
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
Question edited for clarity, full 'make model (what it is)'.
This a Menards special. To remove handles, look for a small hole hidden from the front. They take a small Allen Key.
