Tv screen had vertical limes and horizontal lines...big lines
The cause can be a very great problem if all capacitors are must replaced , because they can be deformed by extreme heat build up a clogged airiation bad working fan or fine dust filter. then it must be a new board The place where a projection television is set that can have blocked the airflow.
Hi, can you tell me what you see on the screen? It could be a bad cable. Are you using an HDMI cable or the color cables (RCA cables)?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Testimonial: "its not the cable for sure ..actually when u turn the tv on without any cables ....as soon as u turn the tv on blue screen comes on and says mistubishi...even that not clear."
I see. If the screen does come on, can you try changing the TV input on your TV remote. look for Source or TV Video and and change to another looking for the correct input to receive cable tv.
I did and its the same thing ...doesn't matter what u do on tv , the picture still the same....I am really starting to believe its the dmd board...unless u know something I don't know. and I don't want to waste this tv without trying to fix it .
