Washing Machines Logo
Gerry O' Grady Posted on Jul 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosh classic washing machine fault no F 21
Bosh classic 6 1200
Moses Simiyu
Level 2:
Habit-Forming:
New Friend:
  • Expert 72 Answers
  • Posted on Jul 21, 2016
Moses Simiyu
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
72
Questions
0
Helped
15287
Points
259
Kindly read the manual or see a specialist.
Is there a reset button for the bosh maxx 1200, A's I layed it on its side and now won't turn on
Here is a link to the Bosch Website. You will need some model info and follow the link to a service/user manual to help you solve you "No Start" condition.
Instruction Manuals
L have a Bosh washing machine and l am having anE17 on the screen can you please tell me what the problem is?
please go onto the Bosh website for a user manual there usually free to download eric
My bosh max classic won't stop filling with water
replace the inlet water control diaphragm or solenoid
How to register my new Bosh washer
You can do so online here: http://www.bosch-home.com/us/support/product-registration.html
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Bosh wasmachine doesn't was clothes
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
My Bosh washing machine has excessive vibration according the the level i put on the top of the washer it is level, but still seems to walk accross the floor on the final spin cycle.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
8helpful
3answers
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Top Washing Machines Experts
john h
