Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Most washing machine motors have no brushes. They are induction motors. And they are made so cheaply that they are welded together hence they cannot have the bearings or many other parts worked on. They may have a centrifugal switch that can be rebuilt or replaced.
Contact the vendor!!! I assume it is still under some sort of guarantee/warantee? You can nulify any guarantee if you attempt to fix problem before contacting vendor.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if
the washing machine does not drain or empty the water out this repair was done
on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated
for answering your FREE question.
