On Maytag RTD2100CAL, I am looking for the location of the defrost timer and how to access it. Thanks
It is a top freezer type. No air coming down into refrigerator section and not as cool as I think it should be. When refrigerator is set to 9 max, ice appears on ceiling of refrigerator section. If you have a service repair manual that would be really appreciated. Thanks
Re: On Maytag RTD2100CAL, I am looking for the location...
Hello Barry,
Indeed it does have a defrost timer...
(bottom/back, access from the back side).
The absolute part number is wp68233-2.
If you have the VENTS SMOTHERED with freezer contents... MOVE them away from the vents... Your freezer will resume normal operation... ALTHOUGH A SERIOUS DEFROST is always recommended...
Use NO HEATERS... fans & room air should be more than adequate... (heat can easily damage the interior panels of your freezer). Do have a pile of shop towels... & your wet/dry vacuum ready...
Defrost pans are not designed for the end of the ICE AGE.
- defrost circuit failure...
(there are only 3 basic parts to the DEFROST CIRCUIT)
- heater(s)... very unlikely
- defrost thermostat... unlikely
- clock/timer... most likely (easiest)
The first thing you want to do (after removing power) is inspect the timer ...
(take LOTS of pictures before REMOVING ANYTHING).
Timers are pretty easy to check... (but MUST be turned in ONLY ONE direction)... You can see the center shaft... and if you mark it with two dots (one on the body & one on the center shaft) ... you will then be able to watch the dot turn away from the other dot as the center shaft rotates.
(again) Before you remove anything take LOTS of USEABLE pictures. You will need to put every wire & screw exactly back from whence it came!!
If our first gyess is wrong... your prize is a SPARE TIMER... move on to the DEFROST THERMOSTAT
Hope this helps... Comment me back if you are unsure about anything (I'll be around).
Prices may vary but the parts are ALL THE SAME.
Two screws... 4 wires
Can be a REAL PROBLEM if you mix them up...!!
DEFROST PROBLEM The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad. With an ohm meter it should show continuity when cold and none when warm. You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad. With an ohm meter it should show continuity when cold and none when warm. You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If the damper(vent) is open and the freezer fan is blowing then it may be a defrost problem.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
cycle and starts back when the timer advances through the cycle. If this ice is not melted it will continue to
is usually noticed first followed by the freezer. If the defrost thermostat is bad it can prevent the heater from
cold and none when warm. You can also bypass the thermostat to see if the
replaced. The defrost heateris
voltage when it’s in the defrost mode. If
you have a defrost
timer you
everything starts back up to end the defrost cycle. If you have an adaptive defrost control instead of a timer,
Normal
0
font-size:10.0pt;
mso-fareast-font-family:"Times New Roman";}
you have a defrost
timer you
you have a defrost
timer you
you have a defrost
timer you
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
If the ice is on the floor of the freezer
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer. OR If the ice is on the back of the freezer The evaporator coil behind the cover on the back
you have a defrost
timer you
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it.There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
