Troubleshooting & Support
Hot Topics:
- water dispenser...
- lock unlock...
- leaking water
- clean coil
- water filter
- maytag repair...
- remove...
- door alarm
- problems amana
- filter
- fan air freezer
- maytag...
- door handle
- Refrigerator...
- leak water...
- refrigerator...
- removing front...
- door alarm...
- HUMMING
- ice
- hum
- water leak
- freezer light
- freezer handle...
- set controls
- vegetable...
- refrigerator...
- problems
- Refrigerator
- View All »
Problems & Solutions
CALLED A REPAIR MAN OUT. REPAIR MAN SAID THE
Rare but possible. I suggest that you order the part yourself and call a serviceman to install it for you. That may be a way to circumvent...
The water is coming out very slow in water
HI. Usually this will be the cause of a damaged valve or a mineral build up inside the valve that will not allow the valve to open fully....
icemaker makes ice but wan't despense, also...
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
the water that feeds into the icemaker has frozen
use a hair dryer to defrost the line ......
Hello, my freezer handle broke
Hi, That is not that hard to fix and you can easily buy the parts yourselfonline... Here is a tip that will help you with the online...
handle on bottom freezer door
Hello, You need to look at the screw at the bottom of the handle. I know this is difficult to do; however, you have to establish what type...
MAYTAG MFI2067AES ICEMAKER NEEDS REPLACING
2 things possibly: check brackets and see if they need to be moved inward or outward as in they have bracket catches on the brackets so when...
Maytag digital panel click on, then off. ...
The fault may have three places that it could come from. The Digital Logic Panel itself the motherboard or the low voltage transformer. If...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant...
maytag refrigerator start device broken
Whirlpool refrigerators as well as the other brands that fall under the corporation most like at some point within the first five years will...
icemaker makes lil ice cubes now could this mean...
Would not expect you to ask this question but yes you are right cajunboudoin, an obstructed water line by either a defective water control...
Ice forming inside freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and...
how do you know it is compressor or overload/relay
Most times it is the start relay and overload. But to test compressor you will need someone with a voltage ohm meter to follow the...
Maytag side by side msd 2656, ice cubes melts
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
maytag mbf2258Wew1 bottom freezer has ice on the
The drain in the freezer behind back lower panel needs opening. You can see it at the bottom of the back panel underneath the evaporator...
See all Maytag MFI2067AES Stainless Steel Bottom Freezer Solutions
Unsolved Problems
ice maker is not getting water
Water is fine coming out of the dispenser in the door
maytag MFI2067AES
my lights inside dont work try almos everything the ice maker not working the water dispenser not working but the rest...
Richard: Maytag Refrigerator MFI2067AES Door Alarm...
Door alarm light and beeping will not stop, all doors are closed. I tried unplugging the fridge and resetting it, but...
Fridge door alarm
Fridge door alarm light flashing, tried resetting the fridge by unplugging, didn't work as the fridge started to...
Maytag fridge alarm light flashing
Door alarm light flashing and fridge lights are out. I have checked all doors and they appear to be closed properly. I...
I have a Maytag MFI2067AES.
I have a Maytag MFI2067AES. The water comes out in spurts and makes a really loud noise. When the ice maker tries to...
Our freezer door handle came
Our freezer door handle came off. How do you put it back on and tighten it?
See all Maytag MFI2067AES Stainless Steel Bottom Freezer Problems
Upload a manual for Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator
Specifications
TopKey Features
Full Product Name:Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator
Number of Motors:1 Motor
Total Volume:20 cu. ft.
Installation:Free-Standing
Refrigerator Type:Bottom Freezer
Refrigerator Type:French Door
Dimensions
Overall Depth:30.38 in.
Overall Height:70.13 in.
Overall Width:35.63 in.
Warranty
Warranty:1 Year Parts and Labor
Convenience
Exterior Color:Stainless Steel
Defrost:Automatic Defrost
Fresh Food Compartment
Fresh Food Shelves / Bins:Gallon Storage
Fresh Food Shelves / Bins:Snack Drawer
Fresh Food Shelves / Bins:Dairy Center
Shelf Material:Glass
Door Opens:Opens to Left and Right
Light:Yes
Ice Maker
Dispenser:Water
Dispenser:With Water Filter
Dispenser:Ice
Energy
Annual Energy Consumption:555 kWHrs
Energy Efficiency:Energy Star Compliant
What's your problem?
Fix-O-Meter
1,827
1,827 people have viewed this product
- 28 people asked about this product.
- 9 people found solutions for this product.
- 4 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
