The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
