SOURCE: Yamaha RX-770 Receiver display quit
there is a bulb inside the backlight on the lcd display.it is 12 volt and alot of manufacturers run it from the +- 15 volt preamp power supply,on the plus rail.when the bulb burns out it can activate the dc speaker protect,or some other 12 or 15 volt circuit..if it is a flourescent display that is a different problem.those run on 5 12 18 and -32 volts.there is also a 6 volt ac filament voltage.you need the schematic.
SOURCE: I have a Yamaha RAV 370 remote, and want to use it for a Topfield
It can be 737, but I'm not sure... //David
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
SOURCE: How can I get hold of a new remote for a yamaha rx
The model is RAV250 (roiginal) or RAV254 (sub)
Read this first:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12987331024191
Searched eBay, found a couple RAV254's for $35 and $43 ...
"rx v450 remote" check the 'include description' box
or ...
$54
http://remotes.com/remotes/servlet/rs?&o=c&o=c&a=Search&uid=0&m=rx+v450&uuid=A12987330771381
