Yamaha HTR-5650 6.1 Channels Receiver
Problems with Yamaha HTR-5650 6.1 Channels Receiver?
Troubleshooting and Support
Solved Problems for Yamaha HTR-5650 6.1 Channels Receiver RSS Feed Post a New Problem
no surround sound
my probllem is i cant turn the rear volume speakers up there is no sound from right or left rear speakers what do i do?
1 Solution
RECEIVER WILL NOT TURN ON.
Hooked up to 4 speakers for 3 years. Played great. Recently kept shutting down 5 minutes in and had CHECK SPEAKER WIRES...
1 Solution
minimal sound from the sub, all other...
old sub blows fuses i think its cuz the power went out in the house 1 time, anyway i removed and replaced the sub with a...
1 Solution
minimal sound from subwoofer
1 Solution
htr-5650 2 channel only...no 5.1...HELP!
Having trouble acheiving 5.1 sound...I am stuck on if it is a connectivity issue or setup issue...I have downloaded the...
2 Solutions
Pre amps
I have a 5 year old Yamaha AV receiver - Yamaha says that to run a turntable I need a pre amp - what product would that...
1 Solution
No sounds from rear speakers..... Yamaha...
Team - I cannot get any sound from my rear speakers (Fronts, Rears and Sub) on my 6.1 Yamaha Amp (HTR-5650). When I work...
1 Solution
Unsolved Support Problems
Unsolved Problems for Yamaha HTR-5650 6.1 Channels Receiver RSS Feed Post a New Problem
Audio Inputs Not Working
Hi, It seems my audio inputs are no longer working. I have tried using digital optical, digital coax and analog coax,...
Post a Solution
ps3 to htr 5650 reciever
how do u connect ps3 with hdmi cord and get surround sound
Post a Solution
User manual for GE clock radio model...
I need to find the user manual for GE clock radio model 7-4606BKA Please tell me where I can find this online?
Post a Solution
no sound to outside speakers (b button -...
I don't have any sound to the outside speakers speakers (yamaha htr-5650). 6.1 inside speakers ok. Any ideas?
Post a Solution
Yamaha HTR - 5650
I have a Yamaha HTR 5650 AV receiver. I experience extreme audio skipping when watching DVDs. I have replaced my audio...
Post a Solution
DVD sound skips while using Optical Cable
I have my dvd player hooked up to my hrt5650 using an optical cable but when I try to listen to it the sound skips on...
Post a Solution
yamaha 5650
The main speakers are okay, I cannot get any sound out of the rears or center. I think that I have programmed correctly....
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
TypeReceiver
Surround SoundDolby Digital® · DTS® · DTS ES® · Dolby Pro Logic II
Number of Channels6.1 Channels
Stereo Mode Power80 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.06%
Surround Mode Power80 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.06%
THX CertificationNo
DSP
DSP ModesHall · Theater · Music Video · Entertainment · TV Theater · Rock Concert
DSP Processor Type(s)32 bit Processor x 1
Inputs / Outputs
Rear Input ConnectorsComponent x 2 · Digital Coaxial x 1 · Composite (Video) x 3 · S-Video x 3 · RCA (2 Audio Channels) x 5 · Digital Optical x 3
Surround Analog Inputs5.1 Channels x 1
Preamp OutputsSubwoofer
Rear Output ConnectorsComposite (Video) x 2 · Component x 1 · Digital Optical x 1 · RCA (2 Audio Channels) x 2 · S-Video x 2
Front A/V ConnectionsHeadphones x 1 · Composite x 1 · Couple RCA Jack x 1
Component Video Bandwidth30 MHz
Convenience
Tuner Presets40 Channels
On Screen DisplayWithout OSD
Tone ControlsBass & Treble
Speaker Impedance4 ohm · 8 ohm · 6 Ohm
Speaker SelectionA+B or A/B
Remote Control
DesignKeypad
Dimensions
Depth15.38 in.
Height6.38 in.
Width17.13 in.
Weight24.25 lb.
Warranty
Warranty2 Years
Yamaha Contact Information
Main support number1 800-492-6242
Sponsored Links
Loading problems.
Top Experts
Ask Me
CABLE CUY Wiz
8 solutions
Ask Me
HDTV GURU Guru
5 solutions
Ask Me
sserpenti Guru
3 solutions
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
