In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
If you do so, then the router will no longer work in 90% of cases.
The WiFi protected setup is enabled by default in this model.
The computers using XP,vista,win7 may not connect to the wireless network.
Solution: In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system. WINDOWS XP: Start>Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication WINDOWS VISTA: Start>Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication WINDOWS 7: Start >Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
Now try to access wireless network.
If it still says windows cannot connect then no other go.
You need to disable WiFi protected setup.This will fix the issue for sure...
You will get an 'authentication' problem trying to connect to this dlink 600 or any other wifi services/routers that are 'protected' and encrypted using WEP or WPA or WPA2 security (e.g. not public or 'OPEN' network): apart from the SSID, you will need to set your android tablet or ipad to use the WEP or WPA or WPA2 PASSWORD/PASS KEY to successfully connect (you get it from the Wifi/Router administrator).
Yeah, they confirmed that they have some problem on some wifi authentication especially when your AP is configured to WPA-PSK (TKIP or AES).
you can only connect wifi with open, shared, WEP 64 and 128bit authentication and WPA/WPA2.
Samsung still dont have any solution to this big issue. Been a lot lately to customer service in plaza sing, talked to the manager a lot with this problem, still NO SOLUTION. You can't even have a full refund, no change model.
