20 Most Recent
Craig CMP741d Tablet Questions & Answers
Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections6. Use the volume buttons to move up and down through selection in this menu7. Using the volume down button, scroll down to "Wipe data/factory reset"8. Tap Power hard key to select option9. Scroll down to select "Yes, delete all user data"10. Tap the power button to select. Wiping and formatting data will take a few minutes.11. You will return back to the Android recovery screen menu.12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
How to install google play
The Google Play is pre-installed in all Android Phones and Tablets. If it is not pre-installed it's either not Android or check the Google Play Website and try to download any App after registering a Free Account :https://play.google.com/store
My craig tablet has a white screen and will not
You'll need to do a factory reset:1. With the device off, press and hold Volume Up and Power.2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.4. Press Volume Up continue.
My sons friend changed his password and everytime I go to reset it it just turns off. How do I reset?
- First, switch your tablet off.
•Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously.
• Continue holding the volume button until the screen says "Booting tablet in recovery mode."
• This will give you a picture of an Android.
•Tap the android, and you will be given a screen with several options.
•Move between the options with the + and -, and select with the power button.
•Go to the option for Factory Data Reset and select it.
•Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings.
•Once it has completed, select Reboot Tablet Normally.
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
